Learn how to be your own tech line…
Sign in to follow this
Followers 0
frunch
Whirlpool Coin-Op washer CAM2752TQ3 only fills 4-5" of water in tub
8 posts in this topic
Got a call from a customer with a relatively new (less than 1 year old) Whirlpool coin-op washer where it's only filling the tub with approximately 5 inches of water. Haven't been out there to check it out yet, but thought I'd see if anyone has any suggestions where I might start looking for the source of the problem. I can see this washer incorporates 2 water level switches, so I figure that will be the place to start. I'll be going to check them out within the next day or 2, so I'll report back with any further information I can gather. Again, the model # is CAM2752Q3 and it is a coin-op direct-drive Whirlpool washer.
Any suggestions?
Trevor
  If this is only happening on the rinse cycle, that is normal operation. The second pressure switch is for rinse level which is very low to meet government regulations regarding water usage.
Eric
Well, I just got a chance to take a look at it today, and I believe Eric might have this one nailed. It is filling to the appropriate height for the wash cycle when the machine is first started, approximately 5” from the top of the tub on the large load size setting. I was misinformed that it was only filling with 5” from the bottom of the tub. This is why it pays to see the problem with your own peepers. Anyway, the other complaint was that it wasn't filling the tub completely in the rinse cycle. I've verified that it is filling only about half the tub in rinse, which is the amount of water the machine fills with on the small load size setting. It sounds like this is normal operation, and that this is part of the energy efficiency laws. Users complain the rinse is leaving suds or soap residue on their clothes. Should I suggest using less soap and possibly 'HE' soap?
http://appliantology.org/files/file/1144-whirlpool-washer-cam2752tq3/
Whirlpool Washer
CAM2752TQ3
Repair Part List - W10436974
Wiring Sheet - W10135801 - Rev B
FEATURE CONNECTOR 2
CONNECTION LOCATION
FEATURE CONNECTOR 2 TO BE USED ONLY ON UNITS SOLD OUTSIDE OF UNITED STATES.
FOR DEEP FILL RINSE WHEN LARGE WASH CYCLE IS SELECTED,
FEATURE CONNECTOR TO BE PLUGGED INTO V-Y WIRE FROM TIMER SWITCH 10A
Thanks for the info and link RegUS! I referred the warranty service since the machine was under a year old, but I may wind up going back. If I do, I will certainly try your suggestion.
Thanks!
Trevor
  What suggestion? I didn't see any suggestion :wink:
Sorry, that was directed at RegUS--referring to a wire connection that will enable a 'deep rinse'. I appreciate your input, though! It helped greatly when I went and took a gander at the machine.
Trevor
  I was joking. The low rinse water level is a government regulation so rather than suggesting that you defeat that, we inform you that it is legal to do so if the unit is used outside of the U.S. Now you know that it can be easily defeated for international use. Whether you choose to do that is totally up to you. By not outright suggesting you defeat the low level rinse, we are not liable for your actions. Same goes for lid switches. We tell people how to defeat the lid switch for testing purposes only. If one chooses to leave it that way, it's on them if anybody gets hurt. We're just covering out butts :wink:
Eric
Followers 0
