legaleagle
Kenmore HE4 dryer taking forever to dry
7 posts in this topic
Model is 110.85872400
We've had this dryer since 1/2006 and it's gradually taking longer and longer to dry, to the point that none of the non-high heat sensing cycles gets the clothes more than damp, even with the "more dry" option.   The timed cycles do still work but are also taking longer and longer - a good 80-85 minutes for full-but-not-stuffed load of regular fairly lightweight clothes (t shirts, etc).   I have cleaned out the dryer vent to the outside fairly regularly and that doesn't really help.  I recently looked around the bottom of the inside of the dryer when I disconnected the vent and didn't see any lint build up.  I also cleaned off the little sensor bars on the inside and am fanatical about cleaning the lint trap.  I have never used fabric softener or dryer sheets.   I have 3 small children and do a LOT of laundry - 10-14 loads a week for the last 5 years.   I found the video on dissembling the duet/he3 dryer, should I take off the front panel and see if there's a secret stash of lint clogging things up?  Anything else I can test?  We have multimeters, etc already.
Dryer Vent 4" diameter
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
$ 3.99 sometimes on sale for $ 2.99
1 person likes this
We have some kind of semi-ridid metal duct back there - has accordion texture but is actually quite stiff.  It does have a small crimp in it from moving around so I can replace.  There's only about 6" max between dryer and wall and they aren't even close to lining up (no side-to-side room to maneuver anyway).  It's held on with those metal clamp things that go around the outside of the pipes - would tape be better?  Or is there some kind of less rigid duct.   It has previously gotten disconnected with some lint buildup behind there but I believe I reconnected it solidly when I checked everything a couple weeks ago.  Vent to outside of house goes down through one of those wall boxes that does a 180 (checked recently t's completely lint free) and is straight and rigid, about 12-14" long.  We have in the past used one of those dryer cleaning kits that hooks up to the shop vac and gotten some lint out but didn't improve the drying much.  I will disconnect and check the vent temp - how long should it take to get up to 130?   How do I measure airflow - is there some kind of minimum flow I need to see?  Thanks for the thermometer link too.
...  I will disconnect and check the vent temp
... how long should it take to get up to 130?
... How do I measure airflow - is there some kind of minimum flow I need to see?
1) see if it dries any faster with the Vent disconnected
2) about 3 mins for my Gas Dryer
3) should be able to feel it with your hand ..
check with Vent disconnected,
then check at outside of house
The crimp in your vent hose would be the most likely suspect.
But a good check would be to disconnect it and see the results like Reg suggests. Is there any lint build up on the door?
There's no significant buildup on the inside door vent, that I can see.  I did check the air pressure at the outside vent (haven't disconnected the back yet) and it seemed good though there was some lint buildup on the plastic fins so I cleaned that off.  I will get some more flexible metal pipe for the inside connection this weekend and check the other things as well.
