Jenn-air Ref. Mod# JFI2089AEP3
dablacks
Thanks, but that does not cover the programing for this model.
The display board is different. Any suggestions?
Does this sound about right? I couldn't find that tech sheet and whew, was a lot of typing.. and all from memory, just for you.
Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word Code.
1. Press and hold the WATER Keypad.
2. Press and hold LL Keypad.
3. Release the WATER Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
5. Entry is confirmed by pressing the LL Keypad once more.
6. The control will display the current Program CODE. This value should be validated with the Program
CODE printed on the unit serial plate.
NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing water
Keypad for 3 seconds.
7. Press the UR Keypad or LR Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the UL Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the LL Keypad until the Program CODE
begins flashing indicating it has been saved.
NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will
beep. (The unit will NOT run with a Program CODE of 0000).Once the Program CODE has been saved
the Programming Mode is exited by pressing any key or by opening or closing the refrigerator door. If
the new code is incorrect this process should be repeated.
The Programming mode can be exited at any time by pressing WATER key for 3 seconds or will exit if
unattended for four minutes.
Defrost Operation:
The Control Board adapts the compressor run time between defrosts to achieve optimum defrost intervals
by monitoring the length of time the defrost heater is on. After initial power up, defrost interval is 4
hours compressor run time. Defrost occurs immediately after the 4 hours.
Forced Defrost Mode:
Enter the Forced Defrost Mode by performing the following sequence of events:
2. Press and hold LR Keypad.
3. Release the WATER Keypad and wait 3 seconds. Fd appears in the left side of the display.
4. Press the LR Keypad again. Sh appears in right side of the display.
5. Press LR again to force defrost Fd and Sh will flash in display indicating unit is in defrost.
Service Test Mode:
Enter the Service Test Mode by performing the following sequence of events:
2. Press and hold UR Keypad.
3. Release the WATER switch and wait 3 seconds.
4. The display will show SE confirming entry in the Service Mode.
5. Press the UR Keypad again to confirm entry in the Service Mode.
6. Display will show 101 in left display and numeric or dashes in right display.
7. Press UL Keypad and LL Keypad to toggle through Service Test numbers.
8. To exit service test mode, open and close refrigerator door or hold door alarm for 3 seconds.
Service Test - 101 Defrost Heater & Defrost Circuit
• Press the UR keypad or LR keypad to energize or de-energize the Defrost circuit. The display will
read OFF when de-energized, OP when energized with open defrost thermostat and CL when
energized with closed defrost thermostat.
Service Test - 102 Compressor / Condenser Fan
• Press the UR keypad or LR keypad to toggle Compressor/Condenser fan On and Off.
Service Test - 112 Freezer Fan
• Press the UR keypad or LR keypad to toggle Freezer Fan On High speed, Low speed and Off.
NOTE: Display will show state 0.0 for OFF, 11.0-14.0 volts for High speed or 7.75- 8.25 volts for Low
speed.
Service Test - 113 Ice Compartment Fan
• Press the UR keypad or LR keypad to toggle Ice compartment Fan On High speed, Low
speed and Off.
speed.
Service Test - 121 Damper Operation
• Press the UR keypad or LR keypad to toggle Damper (OP) open and (CL) closed.
NOTE: When damper is opening or closing it will display "--" if damper state is unknown. It can also
show "DP" it damper is moving when initially entering service mode.
Service Test - 131 Mullion Heater
• Press the UR Keypad or LR Keypad to toggle Mullion Heater Off and On.
Service Test - 141 Fresh Food Thermistor
• Will Show Fresh Food Temperature or OP for open thermistor or SH for shorted thermistor.
Service Test - 142 Freezer Thermistor
• Will Show Freezer Temperature or OP for open thermistor or SH for shorted thermistor.
Service Test - 144 Ambient Thermistor
• Will Show Ambient Temperature or, OP open thermistor or SH shorted thermistor.
Service Test - 145 Ice Box Thermistor
• Will Show Ice Box Temperature or, OP open thermistor or SH shorted thermistor.
Service Test - 151 Fresh Food Door State
• Will show state of Fresh Food Door. OP (open) CL (closed).
NOTE: By pushing either fresh food door switches you can toggle state from OP (open) to CL (closed).
Service Test - 152 Freezer Food Door State
• Will show state of Freezer Door. OP (open) CL (closed).
NOTE: By pushing freezer door switch you can toggle state from OP (open) to CL (closed).
Service Test - 153 Disable Internal Lights
• Press the UR keypad or LR keypad to toggle Enable (En) and Disable (dIS) internal lights.
Service Test - 163 Water Dispenser
• Display shows the state of the Water Dispenser Valve (On or OFF).
NOTE: By pushing Actuator pad or Express Fill keypad you can control state of Water Dispenser Valve.
Service Test - 164 External Ice Chute Door
• Display shows the state of the External Ice Chute Door CL (closed) or OP (open).
NOTE: By pushing Actuator pad you can control state of External Ice Chute Door.
Service Test - 165 Dispenser Lamp
• Display shows the state of the Dispenser Lamp (On or OFF).
NOTE: By pushing Actuator pad or Express Fill keypad you can control state of dispenser lamp.
Service Test - 167 Cavity Heater Test (On some models)
• Toggles the state of the Cavity Heater On or OFF.
NOTE: Pushing UR OR LR keypads toggles the cavity heaters state to On or OFF
Service Test - 168 Cube Dispenser and Internal Ice Chute Door Operation
• Display shows the state of the ice auger motor and the internal ice chute door. (On or OFF)
NOTE: By pushing actuator pad you can control state of the Ice auger motor and the internal ice chute
door.
Service Test - 171 Actuator Pad
• Display shows the state of the Actuator Pad (On or OFF).
Service Test - 172 Front Fill (On some models)
• Display shows the state of the Front Fill (On or OFF).
Service Test - 173 Ambient Light
• Display shows light sensor measurement (Hi or Lo). Night light will turn on when light sensor
measures Lo. By changing the sensor's exposure to ambient light you can control the sensor
measurement.
Service Test - 175 Dispenser Switch
• Display shows the state of the Dispenser Switch (On or OFF).
NOTE: By pushing Actuator pad or Express Fill keypad you can change state of Dispenser Switch.
Service Test - 182 LED Indicator Operation
• Press the UR keypad or LR keypad to show operation of LED Indicators. All LED Indicators will
flash. Press again and LED will stop flashing.
Service Test - 183 Keypad Operation
• Display shows a numeric or letter display indicating the last key pressed.
NOTE: UR and LR keypads have no effect when pressed and UL and LL keypads remain operational.
Service Test - 192 Ice Maker State Test
• Display shows "dr" if left fresh food door switch is in the door open position.
• Display shows "OFF" if ice maker power switch is in the off position and door closed.
• Display shows "On" if the ice maker power switch is in the on position and the door closed and
heater is off.
• Display shows "OnH" if icemaker power switch is in the on position and harvest heater is on and
door closed.
Service Test - 193 Ice Maker Relay
• Press the UR Keypad or LR Keypad to toggle the ice maker relay On and OFF.
NOTE: Service tests 201-213 modify factory settings to suit customer's needs.
Service Test - 201 Mullion Heater Override
• Press the UR or LR Keypad to change Mullion Heater from cycling on with compressor (OFF
position) to 100% operation (On position).
NOTE: If present, the Humidity Control Button toggles between the selected Mullion Heater
Function and 0% operation.
Service Test - 202 Default Defrost Operation
• Press the UR or LR Keypad to change Defrost Operation from normal adaptive defrost
(Off position) to minimum time between defrosts (On position).
Service Test - 203 Show Temperature Set points - Disregard this Test - Unit will not display actual
temperature only set temperature.
Service Test - 211 Fresh Food Temperature Adjustment
• Press the UR or LR Keypad to change calibration of Fresh Food Temperature plus or minus in
1°F increments up to 6°F.
NOTE: Temperature will read in Fahrenheit regardless of what current temperature scale is being used.
Service Test - 212 Freezer Temperature Adjustment
• Press the UR or LR Keypad to change calibration of Freezer Temperature plus or minus 1°F in
Service Test - 213 Ice Compartment Temperature Adjustment
• Press the UR or LR Keypad to change calibration of Ice Maker Compartment Temperature plus or
minus 1°F in increments up to + 0 / + 8°F.
Service Test - 221 Reset Default Settings
• Press the UR or LR Keypad to reset to factory default settings (dEF).
Service Test - 231 Water Filter Usage
• Display shows the percent water filter consumption since water filter was reset. 100% indicates
the filter should be replaced.
Service Test - 232 Water Filter Days In Use
• Display shows the number of days since the water filter was reset.
Service Test - 241 Software Revision Main Control Board
• Display shows the Software revision of the Main Control Board).
Service Test - 244 Software Revision Display Board
• Display shows the Software revision of the Display Board).
NOTE: Disregard Service tests 3XX and above. Codes are used for engineering purposes only.
...  tech sheet is # w10238851. Anyone have this?
... I couldn't find that tech sheet and whew, was a lot of typing..
... and all from memory, just for you.
:whistling:
http://appliantology.org/files/file/1153-jenn-air-fridge-jfi2089aep3/
Jenn-Air Fridge
JFI2089AEP3
Repair Part List - W10297595
Tech Sheet - W10238851
This sounds more like it! I don't know where you got it from, but if you type like me (two finger style) that would have taken you all evening. I definitely owe you a beer or 6. Amazing how our business has changed in the last decade! Thanks!!!
