ReliableApp
Amana Washer ALW8800AW tripping the breaking instantly.
4 posts in this topic
-looking for advice on how to trace this problem if someone has heard of this before.
-parts that could be failing and how to test?
Start at the terminal block.  Unplug dryer.  Check resistance from L1 to N and from L2 to N.  Whichever one gives you low resistance is your problem circuit.  You've split the problem in half and can focus on that side of the circuit.  Now look at the wiring diagram and go hunting.
Thanks for direction I should start it.
The run capacitor by the motor had fallen out if the clamp and the terminals were sparking on the clamp, thus tripping the breaker.
Easy fix, resecured the capacitor and it worked fine.
Nice find!  Domo for posting it.
