Jive Turkey Repairman of the day
2 replies to this topic
#1 Scottthewolf
Scottthewolf
    Senpai
  • 2,957 posts
Posted 17 August 2013 - 12:05 AM
Just when I've seen it all, I've run into a repair done by a Jive Turkey Repairman on a GE dryer.  Instead of replacing a whole control panel because the tabs that hold the rotary start switch in are broken, he used plastic zip ties to  hold the switch in the control panel.  Well, the zip tie he used finally broke.
The moral of the story is, repair the unit back to the original factory condition, don't cut corners.  It will only create call backs. If you do cut corners by trying NOT to order or replace parts, make sure you tell the customer what you are doing and that you cannot warranty the repair.
Do it right or don't do it at all.
Scott Wolf
#2 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 975 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 17 August 2013 - 09:11 AM
Done that same exact repair once... Customer didnt want to pay for the replacement parts... Less than 3 months later get a call back... Change of heart!!!
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 17 August 2013 - 09:44 AM
... Done that same exact repair once... Customer didnt want to pay for the replacement parts...
25 Piece 12" Stainless Steel Cable Ties
Super-strong stainless steel cable ties hold fast where others fail.
Fully rounded edges and smooth surface to protect cables.
  • 115 lbs. working load
  • High strength, nonflammable, noncorrosive 304 stainless steel
  • Maximum loop diameter:3-5/8"
http://www.harborfre...ties-69413.html
