allowingtoo
PSS26SGPA Diagnostic Mode?
119 posts in this topic
PSS26SGPA - is there a diagnostic mode for this fridge?  My freezer is slowly getting warmer day by day.  And it's not the freezer flap this time :(
It started out at 12 when I first noticed it and now it's up to 19.
You watch this video and some ideas, but make sure all fans are working and have a good frost pattern in freezer and make sure all doors lights are shutting off when door shuts.Diagnostic mode is not always the best method.Voltmeter and checking out components is where this is going to help you the most.
1 person likes this
I found this page
http://appliantology.org/files/file/853-diagnostic-modes-manual-for-ge-refrigerators-multiple-models/
And tried to download it and of course it said I had to be an Apprentice.
http://appliantology.org/concierge/apprenticeships.html
The link on that page
STEP 2: SELECT EITHER THE APPRENTICESHIP ($10) OR THE APPLIANTOLOGIST ($55) MEMBERSHIP PACKAGE ==> CLICK HERE.  The upgrade is instant and automatic.
Just takes me to MY CURRENT SUBSCIPTION PAGE.  There is no where to select or pay $10.00.  (or even $55)  You make awfully hard to give away money :)
I didn't know you had to plug something in to make that work....
I unplugged the fridge for a bit and then plugged it back in.  Right now the freezer is at zero again.  We'll see.
... I didn't know you had to plug something in to make that work....
second line of video:
"If the Refrigerator does not have TouchPad temperature Controls ....
I believe yours has this Control
User-Control-and-Display-Board-WR55X1039
No I do have touch pad controls.  It was plugging something in to the top left hand corner of the fridge at the very start of the video.  My touch pad looks exactly like that.  I just don't have the two control knobs above that.
BTW I've tried turning the freezer down with the touch pad but it just ignores me.
It's got a lot of ice crystals built on on the back wall.....
... No I do have touch pad controls.
... My touch pad looks exactly like that.
1) you don't have Touchpads ?
2) you do have Touchpads ?
PSS26SGPA
Is that your full model number ?
1 person likes this
I DO have touch pads.  And yes, that is my model number.
We figured out the model number way back when.....
PSS26SGPA
The video is generic for a lot of models.You have the same touch tone pad as in the video and you would just forget about the other stuff until he gets to how to put in a diagnostic mode.
Edited by bigbuck
I don't have a diagnostic test harness.
I'm still reading through the forum.  Isn't the ice wall on the back of the freezer significant?  Would it be the heater?  Or the thermostat?
I know the motherboard should come into play about now :)
... I don't have a diagnostic test harness.
...  Isn't the ice wall on the back of the freezer significant?
1) You already have the Touchpad Controls
you don't need the Diagnostic Test Harness unless your Fridge only has the two Dial Controls
2) yes, you should remove that Evaporator Cover and post some pictures of the Evaporator frost pattern
OK, it's late though.  Going to have to wait until tomorrow.  Since I unplugged it - it's back up to 23 :(
It stayed at zero for a while.  I think until we pushed it back up against the wall.
Since you have unolugged it you may want to Put towels down to catch the water, don't want to ruin your floor.
I plugged it back in.  That's why it's back up there to 23 degrees.
If I just replaced all the possible parts, what would they be?  Besides the motherboard?  There can't be that many that would make the back wall freeze up.
... If I just replaced all the possible parts, what would they be?  Besides the motherboard?
... There can't be that many that would make the back wall freeze up.
Defrost-Thermostat
http://www.repairclinic.com/referral.asp?R=154&N=1170024
Defrost-Thermostat-WR50X10068-00653957.j
Defrost-Heater-Assembly
http://www.repairclinic.com/referral.asp?R=154&N=914088
Defrost-Heater-Assembly-WR51X10055-00910
there's (4) Thermistors
(2) in Fridge / (2) in Freezer
http://www.repairclinic.com/referral.asp?R=154&N=914093
Evaporator-Fan-Motor
http://www.repairclinic.com/referral.asp?R=154&N=1170107
Evaporator-Fan-Motor-WR60X10185-01534724
Main-Control-Board
http://www.repairclinic.com/referral.asp?R=154&N=1531075
Main-Control-Board-WR55X10942-01091474.j
1 person likes this
I found this page
This is a glitch from when we migrated from the old forum software.  People with accounts at that time cannot see the subscription options in the here.  The easy work around is to simply create a new account here.  Let me know if you need me to free up the email address associated with your current account if you'd like to use it with your new account.
IMs-Yy2M8Y_mdHhSxPsFtZmLgAsa9Gk5oBkrmk6I
I'm not seeing a picture there but I'm going to post it anyway.  There is a top shelf that I don't see any way of removing.  The front I can but not the back.  Is that the wall that you want me to remove so that you can see the frost pattern?
goodness - there is NO WAY to edit your post here.
Yes please.  I'd rather not be a lowly Grasshopper any more.  I can't even *Like* your post as I've reached my whatever Limit I didn't have for the day :)
I've freed-up the email address you had associated with your username, allowingtoo.  You can now create another account with a different username using that same email address.  The subscription options should then show up for you.
Well I'm not going to change horses in mid stream, so to speak - until I get this Freezer sorted out.  I'm logged in with FB anyway.
Why don't you just do the free option for Apprenticeship?
