eindhoven88
WARM FRIDGE FREEZER WORKING GOOD
5 posts in this topic
i have a GE gsh22jsta ss all fans are running freezer is at 0 fridge is at 40
all fans run heater works compressor runs
what is the problem
? it has an electric door on the fridge side that opens and closes could this be the problem what controls this?
do i need to change the thermosister or the defrost thermostat?
Is there any frost on the back panel of your freezer?
Also, take the back panel off and take a picture of the frost pattern on the evaporator.
A picture of the thermostat may be helpful too.
Does your thermistor have a black silicon where the wires meet the thermistor?
Provided there is no problem with the defrost circuit indicated by a heavy frost buildup on the evaporator and the condenser fan motor is running, there could be an issue with the motorized damper P/N WR60X10215 (comes with the thermistor).  Also check to make sure the ice dispenser door is closing properly.  I usually find the solenoid that opens that door P/N WR62X10055 corrodes and doesn't allow the door to close and seal properly.
frost patern is even
there is no black silicone on the thermistor but the door opens and closes as i open and close the door
the dispencer door works and seals great
how would i check if i am low on R134 a
the electric door from the freezer to the fridge!!! is the one  i was talking about
If you have a nice evenly frost pattern on your whole evaporator, it is unlikely you have a sealed system problem.
Is your evaporator solid ice or lightly frosted? a picture up loaded on photobucket and posted here can greatly help determine the next step.
Edited by micabay
