Kenmore Elite - making noise lower left
3 replies to this topic
#1 3ringcircus
3ringcircus
  • 13 posts
Posted 19 August 2013 - 02:22 PM
665.15972991
Loud grinding/whining sound that emanates from lower left of washer - does this portend any particular failure?  pump, bearings, etc.
Cleaned tub interior and found piece of wine glass - Next step is to clean out impeller/pump housing and see what I find.
#2 bigbuck
bigbuck
    Sōhei
  • Appliantologist
  • 236 posts
  • Flavorite Brew:Red Wine
Posted 19 August 2013 - 03:33 PM
http://www.repaircli...er=665.15972991
Sounds like you may need this seal kit as sometime objects ruin this kit as it tries to chop up anything that gets down into the pump sump.
#3 3ringcircus
3ringcircus
  • 13 posts
Posted 19 August 2013 - 04:44 PM
Thanks for the response.  Would the symptom for needing the seal kit be leakage underneath?
Checked underneath the "hood" and definitely is the main motor/pump.  Just finished removing pump impeller, housing and cleaned a couple of hard items out (olive pit, walnut shell) and put it back together and noise may have gone - ran a quick rinse and then cancel drain with no noise.  running through a normal cycle now and so far no similar noise.  Will report back
    Shōgun
  • Master Samurai Tech
  • 30,170 posts
Posted 20 August 2013 - 06:51 AM
That would be one of them.  The seal also includes new impellers and a bunch of other guts.  Easy job, worth doing. How-to video here:  http://www.repaircli...er=665.15972991
