Kenmore Dishwasher 665-16765691 Leaks Under Door
Kenmore Dishwash 665-16765691 Leak
4 replies to this topic
#1 SnorkleZ
SnorkleZ
  • 4 posts
Posted 19 August 2013 - 04:51 PM
This Kenmore 665-16765691 Ultra Wash dishwasher leaks erratically.  At first small leaks, but much more today.  Loading doesn't matter - leaks even when run empty (I've included a photo of the water level during a leak).
I've replaced the door seal (thought for sure that would fix it!).  No change.  I was suspecting the float switch of making it over fill, but as I saw today the water fills up to touch the bottom of the heater element, which I think is the right height.  This dishwasher has worked perfectly for a decade, so the installation and leveling should be ok.
I guess the next step is to take off the door and see if anything looks wrong at the bottom?
Any suggestions would be appreciated.
Attached File  IMG_0381.jpg   96.56KB   0 downloads Hmm. This seems to make my posted image a small thumbnail :-(
#2 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 960 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 19 August 2013 - 07:45 PM
Is the the tub where the door seal meets bowed outwards?
How clean is the door and seal area? Clean, lots of elbow grease,
and dry, the outside of the plastic liner in the door, where the seal meets the door. Should look almost new again in color.
Take the bottom cover off! Get eyes down there with lot and lots of light. Is there dust? What about evidence of the leak? Where? Where not? All leaks are visible.
Post a video, YouTube style, to help further our diagnoses.
Also, clicking on your toenail enlarges the picture.
#3 bigbuck
bigbuck
    Sōhei
  • 236 posts
  • Flavorite Brew:Red Wine
Posted 19 August 2013 - 08:31 PM
http://www.repaircli.../3371710/523684
If this vent cover is plug up with gunk it will leak.With the door open like you were going to put dishes in dishwasher it is on the left side with door down.You can pop it out with a screw driver and clean it out in sink and pop it back in.This a very common problem causing leaks on this style dishwasher.
#4 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,022 posts
Posted 20 August 2013 - 07:17 AM
Two other very common things to cause a leak in these models is the plastic bearing ring/seal under the lower washarm being worn out letting too much water out under the arm and causing waves of water to rush under the door dam area.  Also the eight screws that hold the washarm support/pump top cover on can get loose and let the gasket come loose and water will again come out the wrong area and cause wave of water to rush under door area and out onto floor.
William Burk (Willie)
Eureka, CA 95501
#5 SnorkleZ
SnorkleZ
  • 4 posts
Posted 22 August 2013 - 07:51 AM
:yes:  Tentatively FIXED!
Thanks to all of you for your help!  The key was to clean out the plugged vent.  I didn't know that it existed, much less that it
could and should be cleaned periodically.  I popped that cover off and it was GROSS in there - years of sludge.  It looked about 80% blocked.  I never would have guessed that improper air-flow would cause it to splash over the bottom dam.
I was lucky to find a helpful community of dedicated Appliantologists.
