jmartin919
Microwave HV capacitor
9 posts in this topic
I have a GE microwave with a 0.95uF 2100V cap (which is shorted out). Can I substitute a cap of similar value, say 0.98uF. or does it have to be exact? How close does it need to be?
That will work as long as it mounts in the same location.
... I have a GE microwave with a 0.95uF 2100V cap
... Can I substitute a cap of similar value, say 0.98uF. or does it have to be exact?
... How close does it need to be?
usually ±10% is OK
as long as the re-placement Capacitor is equal or higher voltage rating
Is it preferable to go higher or lower? What would be the difference?
The higher uF limit is better, but don't go much over the +10%
The Capacitor "smooths out" the pulsing High Voltage DC
and stores a "reserve charge" between the pulses.
A Capacitor with a too high value uF may give the Magnetron too much "initial / peak" power available.
Thanks. I placed an order for a 1.0uF cap. Will post back with the results.
I installed it yesterday and it's working great. Didn't have to replace the diode. Setup a voltage test using my car battery and a resistor and it checked out ok. Thanks for your help.
