Troubleshoot modern appliances with confidence…
bonefish
whirlpool washer transmissions
4 posts in this topic
#LTE6234AWO
I know there is supposed a pause for the trans. to shift out of neutral to spin, usually changing the timer always corrected this why won't the S.O.B. go into spin until I stop and start the timer?
I've already changed the timer and there is a few seconds that it pauses before the spin but when it starts only the pump is working until I momentarily turn off timer and cut it right back on, then it spins just fine
from the tech sheet:
"MOTOR OFF FOR 3.2  +-.8 SECONDS"
should give enough time for the parts inside the Transmission to "shift into Spin"
You may have a "sticky" or worn Shift Pawl in the Transmission
OR the oil in the Transmission may be a little "thick"
Is this in a "cold" room ?
May need this kit (for inside the Transmission)
http://www.repairclinic.com/referral.asp?R=154&N=2911
some parts may be available separately
some info
787742 #4
Understanding Automatic Washer
