Sign in to follow this
Followers 0
bogreen
Kenmore Dryer Model #110.92822102
6 posts in this topic
Hi,
This dryer will only beep once when the start button is depressed, but nothing else happens.
Buttons all light up and seem OK.
I put it in Diagnostic mode and the timer showed "88" minutes remaining and all the lights
were lit as it was supposed to.
But, again, push the start and just a Beep, and the "88" switched to "06" and then back
to "88"
Any ideas on this?
Bruce
did you do
TEST #6 Door Switch Test ?
No, but I jumped out the door switch and still the same.
how's the Belt and Belt Switch ?
white Thermal Fuse ?
Belt and switch are OK
Yes white fuse jumped out, still no go.
check connections on electronic control board (top left) check for burn spots. Motor control relay located on that board. part number 8557308
Followers 0
