Sign in to follow this
Followers 0
roberto
GE model GFSS6KKYESS frosting up in freezer
4 posts in this topic
We have a GE m# GFSS6KKYESS that continues to frost up in the freezer. Lots of frost. Door gasket is good. Unit is cooling nicely, frost pattern on evaporator looks good. Everything appears to be operating normally. Would anyone have any ideas as to what might be causing this problem. thank you.
Have you tested the evap thermistor and defrost circuit? If you do not find any problems there then you may have a mainboard failure. Post pictures of you evap for better accuracy.
some GE's do frost up quite a bit..
post pictures before and after a Defrost cycle.
Thanks for the replies. We tested for continuity on the thermistor. would anyone know the correct ohm range we should see?
Followers 0
