ToolMaven
Trouble Codes
7 posts in this topic
Does anyone know where I can find a break down of the trouble codes? I am getting " E3 F2". The keypad will not respond.
Model: RBS245PD Whirlpool Electric Built-in Oven
Can you post the rest of the model #?  I am seeing tons of RBS245PD's but  there are more letters/numbers after this and they are different service manual numbers. The ones I looked at did not show any E3 F2  combinations but I may not have seen your manual.  Pegi
Model Number is RBS245PD81
Ser No. XF3201180
The oven when powered up, displays the clock, all button are non-functional. The oven will display the lock icon,(oven door not locked), but when the Start/Enter button is pushed, the lock icon disappears and the clock time reappears. About the only thing that sort of works is the light and even it is
an " iffy " thing. After a period of several minutes the " code " E3 F2 " is displayed and the oven beeps until I cut the power at the panel.
There needs to be a letter after the D so am assuming your 8 is really a "B".  F2 E3 = key held down too long or key is shorted.  See the above link for a manual close to yours and it will show you these fault codes and the suggested repair from Whirlpool.  Pegi
I went back, armed with a magnifying glass this time, and you were indeed right. the Model Number is Model: RBS245PDB1. The " B " looking almost indistigushable from an " 8 ".
A shorted keypad sounds realistic. From the looks of it, the oven will have to be pulled to access the keyboard. Thanks so much for the help.
You are most welcome, thanks for the reply.  Pegi
