Frank Gillis
Kenmore Electric Dryer
6 posts in this topic
Hi. I need advice on my Dryer. The timer stopped advancing a few months ago while on auto dry. It worked ok on timed dry so I assumed it was an issue with the moisture sensor. I replaced the moisture sensor and it worked fine for a few days. Then it stopped working again. I then replaced the timer and the same thing happened, it worked for a few days and then stopped working, it wouldn't advance, even though the clothes were completely dry. What other components can I check or replace? Any help would be appreciated.
Frank
does this Dryer have a model number ?
Hi, Yes, the model # is 110 60852990.
Thank you.....
Thanks for the advice. I'll check it out. The sad part is that when I finish buying all these spare parts I probably would've been better off just buying a new dryer...... I can't pass up the challenge of trying to fix it myself though.....
Also be sure to check the dryer exhaust vent, at the dryer and outside of the house for proper air flow.
