Kenmore 796.80272900 Dryer
6 replies to this topic
#1 pmslightlady
pmslightlady
  • 3 posts
  • Flavorite Brew:Sweet Tea
Posted 21 August 2013 - 03:58 PM
This dryer is working, but it takes 4 hours to dry with a full load.
Sanitize option gets the clothes too hot.  Where do I look first?
#2 sh2sh2
sh2sh2
    Senpai
  • Master Appliantologist
  • PipPipPipPip
  • 756 posts
  • Flavorite Brew:yeunling
Posted 21 August 2013 - 04:13 PM
clogged venting would be the first place to look
#3 Applianceman97
Applianceman97
    Baby Sensei
  • 2,300 posts
Posted 21 August 2013 - 04:51 PM
Check the flapper on the outside of the house. Make sure its not clogged with lint. Then like sh2sh2 said. Check your vent
#4 bayouboy
bayouboy
    Sōhei
  • Chief Appliantologist
  • 145 posts
  • Flavorite Brew:Abita Beer Purple Haze
Posted 22 August 2013 - 08:50 AM
Remove the vent from the dryer and run a cycle, if it dries the clothes in one cycle then it is a venting issue.
#5 pmslightlady
pmslightlady
  • 3 posts
Vent & all lines are clear.  What now?
#6 bayouboy
bayouboy
    Sōhei
  • 145 posts
Posted 22 August 2013 - 09:33 AM
make sure lint filter is clean, blower wheel is spinning. try running on timed dry cycle. check air temp coming out of dryer.
#7 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 22 August 2013 - 09:53 AM
Dryer Vent 4" diameter
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
$ 3.99 sometimes on sale for $ 2.99
