AlexM
GE Frontload Washer Model# WCVH6260HWW; Belt is off and flywheel bent?
4 posts in this topic
So the original complaint was that it was making knocking noise and eventually the belt fell off.
When I went into to back the nut holding the wheel on was a loose and the wheel had been cutting into the tub.
I plan on replacing the belt, but when I tighten everything up, the wheel is still out of true.
Should I replace the wheel and the belt, and call it good? or is there something else wrong?
post-71964-0-31970800-1377121223_thumb.j
post-71964-0-49385800-1377121406_thumb.j
post-71964-0-96165400-1377121413_thumb.j
If the wheel is bent I would change it. It could cause issues in the future.
Dont waste your time replacing that pulley...you have a broken basket support spider or a failed tub bearing, possibly both. Either way, this machine is toast and not worth repair.
I should have looked at the pics. Hes right, looks like bad bearings. I can see the oil splatter in the second pic near the mcu. Not worth fixing.
1 person likes this
