not a pan fan
overheated?
3 posts in this topic
Hello Guru
 I have a overhead Panasonic microwave oven. Model # NN-S263BF. I defrosted some sauce on the automatic setting for about 15 minutes, then cooked it for about 3 minutes. I went about my business not noticing if the oven was powered now or not. The next morning I went to heat my breakfast and I was powerless. I checked the breaker, it is ok. I have no power at all. There is power at the plug that it's plugged into. Did I overheat some very expensive part?
Not a pan fan
... Panasonic microwave ... NN-S263BF
Panasonic Inverter M/W
check the Fuse ... if OK, then Run Away ! :woot:
There is similar service info available, but I don't think you'll want it.
