  • Announcements
Frumby
Ice maker producing very little ice
4 posts in this topic
I have a KitchenAid mod#KSSC48QMS refrigerator. The ice maker is producing very little ice but water is flowing freely from the spigot. I replaced the filter initially but still seems to be an impedance and ice production is limited. I suspect it's the ice maker control module but wanted to hear from the experts if there was something else that I could check. Thank you for your time.
What is the temperature in your freezer? Is the ice maker mold full of either ice or water ? Are your ice cubes that are being made fully formed? Also check the water line to the ice maker to make sure it is not frozen.
Temperature is at 21 degrees. The ice maker does have ice but the ice does not appear to be fully formed...."almost" is a better description. The water line is not frozen.....ideas?
... Temperature is at 21 degrees.
... The ice maker does have ice
... but the ice does not appear to be fully formed....
Freezer needs to be at +15 or colder for IceMaker to "harvest" the Cubes
ideal Freezer temperature is 0F
(you may have other Freezer problems)
Is there any external water filter or Reverse Osmosis water system installed ?
