  • Announcements
w5jv@hotmail.com
Kitchenaid Dishwasher KUDI01ILBS6 won't start
13 posts in this topic
This dishwasher does not get used everyday.  I think it averages being used perhaps twice a week, three times at the most.  It is about five years old.  We always use "normal" and "energy saver dry" and then push start.   When it was new, it would start right away.
Now, when we press start, it does not start and the two green lights go out after about 30 seconds.  The force drain cycle (pushing cancel) does work and two days ago after that cycle, we repressed normal and energy saver dry and the start and it started.  This morning ... nothing... no start.
Doing a Google on this model number yields countless hits of other owners having the same problem verifying what I already know:  KITCHENAID is JUNK.
I am hesitant to spend over a $100 for a new control panel before asking repair people on this list for some input.  The float on the front right corner seems to be free.  The water jet wheel turns easily.  The pump drain cycle works.  The lights above "normal" and "energy saver dry" come on as soon as those buttons are touched, but start does not start the machine.
I welcome any seasoned input.
Thank you.
Actually, your model Kitchenaid is better than the newer units with the Global Wash System.  Since your Cancel button works then the latch assy is most likely ok.  That leaves the touch control panel P/N 8531816.  In my opinion it's worth the repair.
To check the operation of all of the other components, you should still be able to run a diagnostic test cycle.  This test will also reset the main control.  With the door closed, press High Temp Wash/Air Dry/High Temp Wash/Air Dry.  The dishwasher will run a 5 minutes test cycle which will energize every component; inlet valve, dispenser, wash motor, heater, and drain pump.  Allow the unit to complete the test and then check the control operation.  Replace if necessary.
Kitchen aid dishwashers are actually very good units. Worth the repair.
Touchpad and control panel:  http://www.repairclinic.com/vwo1/PartDetail/Touchpad-and-Control-Panel/8531816/1060483
Hello,
You said "With the door closed, press High Temp Wash/Air Dry/High Temp Wash/Air Dry."
My dishwasher buttons are:
CYCLE                                       OPTIONS
Heavy  /  Normal  /  Rinse             Heavy Scrub  /  Energy Saver Dry         START        CANCEL
So ... what do I press now ?  Those buttons are not on my unit.
CYCLE                                       OPTIONS
According to the photo of your touchpad, you do not have "Heavy Scrub"; it looks like "Heated Dry".
"Air Dry" is the same as "Energy Saver Dry"
Okay, thank you.  Well I tried pressing "High Temp Scrub" and then "Energy Saver Dry" in sequence and repeated it once (4 presses) but nothing happens.  Can you tell me if a bad panel can also keep this diagnostic cycle from running?
Certainly-- if the touchpanel is not talking to the key sequence to the control board you will see exactly what you saw:  nothing happening.
Replace the touchpanel:  http://www.repairclinic.com/vwo1/PartDetail/Touchpad-and-Control-Panel/8531816/1060483
Got it.  Thank you!  I will order the part and let everyone know the result.  I appreciate the input and the time you folks took to respond.
PROBLEM: WASHES FOR <30 SECONDS AND THEN SHUTS OFF
Unit may be in Sales Demo mode.
Press the following key sequence in less than 3 seconds to turn Demo mode OFF (or ON):
High Temp Energy Saver Dry Energy Saver Dry High Temp Energy Saver Dry Energy Saver Dry
NOTE: Diagnostics will also clear Demo.
DIAGNOSTICS CYCLE SERVICE FEATURE
Press the following keys in the sequence shown,
while the dishwasher is inactive.
High Temp Energy Saver Dry High Temp Energy Saver Dry
Thank you.  I tried the HT => ES => ES => HT => ES => ES  and did it twice but nothing.  I also tried the HT => ES => HT => ES again.  When the new panel comes in, I will try these then.  Hopefully I won't scramble the new logic :-) ...
The new panel came in and the diagnostic HT => ES => HT => ES worked okay.  It will be another day before we have enough dishes to wash but it sure looks like the unit is responding.  Question:  does this removed panel have any value to anyone or should I just toss it in the recycle bin ??
Toss.
