  • Announcements
boxer
Loose wire on Whirlpool electric dryer LDE5750W2
6 posts in this topic
I have a Whirlpool electric dryer Model LDE5750W2 from 1980 -- worked very well so far, I only had to replace the heating elemt once and now I have a broken belt. I opened it recently because the belt snapped, when I did that I noticed a loose blue wire at the motor -- of the 2 blue wires it is the blue wire closer to the front (see picture below).
The motor has 2 red wires, 2 black wires, 2 blue wires, 1 white and 1 yellow attached to it plus the green for ground, but the sticker on the switch only labels 3 of them as BK, BU, Y and then 1 and 2 in Red. The 3 letters seem to correspond to the wires toward the rear.
The front blue wire seems to have slipped off the post, the connector looks like it has expanded and got loose. Hard to imagine the spade connector just expanding, is that known to happen?
The dryer was working fine until the belt snapped, does that mean the blue wire was on (although loose) and came off when the belt broke? Or is it possible it was always off and the dryer still worked anyway? What does this blue wire do -- what does it connect to or what circuit is it? Does anyone have a circuit diagram or service manual?
Also, can I just crimp the loose connector and put it back on, or do I need to put a new connector on the wire?
Thanks for the help.
Looks like the picture I pasted in didn't get uploaded -- is there a way to upload the picture?
... Looks like the picture I pasted in didn't get uploaded -- is there a way to upload the picture?
grasshoppers can't upload pictures here...
upload them somewhere ,
then post the link here
also, I can't find a wiring diagram for that older model,
unless you have one you could scan & upload somewhere
It's a little older than 1980.  LDE model series of that vintage was 1976-1977.  The serial number will tell the real tale, it's coded with the manufacture year and week.
1980 model year would be LHE.
Well, I purchased it new on Nov 15, 1980, maybe it had sat in a warehouse. Serial No is M04306460.
... purchased it new on Nov 15, 1980,
... Serial No is M04306460.
Manufactured week of:
10/21/1980
