jumptrout
Bottom freezer Maytag Mod.# MBF2556HEB
12 posts in this topic
No power to icemaker.
Anyone have a wire diagram?
Does door switch have to be made for power to I/M?
Thanks.
I already studied that manual.
There is no wiring diagram and no reference to ice maker issues.
 Power is going to  freezer light switch which is a 3 way switch and back to ice maker and breaking circuit with door open.
3 people like this
Meant to say three terminal switch
Reg is dead on. Just did one with the same problem yesterday.
Should be able to hold door switch in and jump the t-stat as usual.  If still no voltage gotta be the wire harness fuse.
2 people like this
Will let ya'll know.
Bad fuse.
Changed harness.
Works now.
3 people like this
Bad fuse.
Changed harness.
Works now.
Almost a haiku.  Let's use it to make one...
Icemaker inop.
Bad fuse.  Changed harness.  Works now.
Margaritaville!
2 people like this
As I replied at ASTI, "always check the black and white thingy."
This is particularly true if the harvester isn't at the normal resting position.
2 people like this
