arrow 1
f24 error 110.47512602
6 posts in this topic
unit would run about 2 minutes shut off flash f24. No other errors found in diagnostics. tested sensor, a little off, so replaced. now when turn unit on it immediately goes to f24? what order of testing is recommended from here? I have read a lot of topics on this but do not find good conclusions. Just a bit confused need a little direction. Thanks
check your connections. if your model has a heater, ohm it. If none of those pose. a. problem then more than likely need a ccu.
Check continuity from the water heater sensor (black wires) to CCU
OK thanks will report back
After double checking all connections, I noticed the connector wiring that plugs into temperature sensor seemed loose where it is attached to the connector. One wire had broken inside connector, after repairing machine is back to normal operation.
Great find!  Thanks for letting us know!
