scootertrs
my FISHER-PAYKEL REFRIGERATOR Model #RX256DT7X1-22600-A water filter leaks
4 posts in this topic
my FISHER-PAYKEL REFRIGERATOR Model #RX256DT7X1-22600-A water filter leaks at the joint between the filter holding base and the filter.  Best I can guess is that the o-rings have collapsed (but they look and feel fine) or since it is a different substitute (a Maytag UKF8001) a supposed equal exchange instead of the Fisher-Paykel no. 13040210 (not locally available and 3 times the money).  I tried plumbers grease on the o-rings and tried new o -rings... still leaks.  Anybody have any experience with this refrigerator being "brand loyal?" I am actually considering removing this filter altogether and putting on an outboard filter.  Any suggestions?
I should add that the refrigerator did not have a filter when we got it and does not have the bypass cap on the filter unit.  Otherwise, it runs and looks new. Thanks.
Same filter, same bypass plug P/N 12664501.  If unit still leaks could be a problem with the filter housing.  Plug is cheap so I'd try that first and go with an in line filter.
Already have one on the way... same bypass plug... Going to also try a thicker outer o-ring.. it is just a shame... it would be so simple.. thank you for the help... it is always good to have you in a "break glass in emergency" pocket... Be safe
OK... still leaks... took it apart and looks like the joint between the blue o-ring plate and the white support plate is leaking.  took it out and blew in it... sure enough... there is the leak.  part number 12590611 fisher & Paykel... have to have other replacements... that one is $83+...  on this site it is $50, but unavailable until 2 weeks or so... going to search now.  If the filter fits so many other units, there has to be a cheaper alternative... any ideas are welcomed.  If this is a common failure issue, please advise, as I will just remove unit (already out and bypass it while using an outboard filter.  Thanks
Edited by scootertrs
