Kenmore dryer 110.66972500
Thermal fuse
38 replies to this topic
#21 bigbuck
bigbuck
    Sōhei
  • 236 posts
  • Flavorite Brew:Red Wine
Posted 22 September 2013 - 11:24 AM
Pull heater out and physically look at it.
#22 Patricio
Patricio
    Opa
  • 1,556 posts
  • Flavorite Brew:Home brewed ice tea
Posted 22 September 2013 - 11:26 AM
Noted in plan of action, 'magnifying headset'
Former Student of Master Samurai Tech School.   Current Student of  Master Samurai Tech School
http://www.mastersam...iliate.php?id=5
#23 Patricio
Patricio
    Opa
  • 1,556 posts
Posted 23 September 2013 - 08:56 PM
Visit again today armed for battle.
  • Both thermal fuse & cutoff open again.
  • Replaced again (this is old)
  • Scrutinized heater element.. normal wear.. nor scorch marks or evidence of grounding.   Full continuity, meter sings
  • Run dryer all heat cycles with vent in tack.. element cycles heat properly within specifications
  • Used a dryer flow tester.. green light.
  • infrared temps behind dryer including vinyl venting range from 88 to 102 degrees
  • Can hear relay cycle on/off.. visually see element glow & darken
Customer does not comprehend air flow, reason because "two previous tenants had no problems with their  dryers"  This dryer has air vents at rear wall of cabinet.  I suggested taken dryer to someone else's home to see if unit will work.  I feel they think that I am blowing smoke at them.
Whatever,  this dryer has cost me time & money.    I have not a clue what to do next.  It works fine pulled out of the closet halfway with no load.   They never have a load for me to dry.   Very frustrating.
#24 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 23 September 2013 - 09:02 PM
... including vinyl venting
:woot:
#25 Patricio
Patricio
    Opa
  • 1,556 posts
Posted 23 September 2013 - 09:43 PM
. :woot:
I don't want to even go there to explain to them the hazards of vinyl.  I already hear it, I have been using this venting forever & have not had any problems
#26 bigbuck
bigbuck
    Sōhei
  • 236 posts
Posted 24 September 2013 - 08:07 AM
Ive  been doing this a long time Pat.You can't win them all and you done the whole10 yards and if people don't want to listen to reasoning What can you do.Charge them a basic service charge or give them money back and move on.You can't wake up every day and have to face this dryer or think what am i going to do if brakes again.I don't like getting beat by any appliance but it happens.And this things in a closet and with vinyl venting and not proper air flow i would tell them about the vinyl duct and wright it down as a fire hazard and charge them a service call or nothing and let it go my opinion. P.S i think where this dryer is install and vinyl duct thats been there for how long is the reason this baby can't be beat.
Edited by bigbuck, 24 September 2013 - 08:33 AM.
#27 Patricio
Patricio
    Opa
  • 1,556 posts
Posted 26 September 2013 - 08:12 AM
Groan:   Dryer from hell people called again.
Dryer pulled out of closet & in hall.   Say cabinet got extremely hot & does not work again.   What's left?    Relay & electronic heat control?   Going to replace,  How do I go about recovering the cost of these?   Already head from them what I charged for initial fuse & cutoff repair was high.
House is up on stilts & exhaust vent goes directly thru floor under house.
It appears that only thing shutting down heat element is thermal safeties.
I probably look incompetent in their eyes.   Bummer
#28 RegUS_PatOff
  • 33,588 posts
Posted 26 September 2013 - 09:37 AM
Vent getting crimped when pushed back into closet location
#29 bigbuck
bigbuck
    Sōhei
  • 236 posts
Posted 26 September 2013 - 02:06 PM
Part number: AP3037419
You could try relay for heater.Maybe its sticking and heater is staying on?When you install the fusible  thermostat on the heater box did you install that back wright?
Part number: AP3135364
Meaning were the box goes back into the rear housing and fits inside like a male connection into a hole.
Edited by Samurai Appliance Repair Man, 26 September 2013 - 03:48 PM.
#30 Patricio
Patricio
    Opa
  • 1,556 posts
Posted 26 September 2013 - 02:30 PM
It lies in a somewhat S pattern, but I definitely made sure it is not crimped.   Besides they say they pulled it out of closet & when that is done it lays straight.
That has crossed my mind several times,  When I am there it works, cycles like it is suppose to.  The thing blows when I am not there.   I now have a relay & heat control board which I will be replacing this evening.  Bummer again.
#31 bigbuck
bigbuck
    Sōhei
  • 236 posts
Posted 26 September 2013 - 02:33 PM
You don't give up i will say that about you.That heat board is money to buy.
#32 bigbuck
bigbuck
    Sōhei
  • 236 posts
Posted 26 September 2013 - 02:38 PM
Hay we were born in the same year.Thought life would get easier?
#33 Patricio
Patricio
    Opa
  • 1,556 posts
Posted 26 September 2013 - 09:48 PM
It was a very good...for pizza & beer...&  all kinds of cheer.
#34 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 960 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 27 September 2013 - 10:35 AM
What kind of load was in the dryer?
#35 Patricio
Patricio
    Opa
  • 1,556 posts
Posted 27 September 2013 - 10:25 PM
Towels I think.
#36 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 960 posts
Posted 27 September 2013 - 11:39 PM
Any chance they over loaded it? Large capacity washer with this dryer? Or is washer/dryer matched set?
http://i1316.photobu...zps330a04cf.jpg
Also are the holes in #5 clear?
What about the plastic screen aka #58?
Edited by micabay, 27 September 2013 - 11:43 PM.
#37 Patricio
Patricio
    Opa
  • 1,556 posts
Posted 28 September 2013 - 10:34 AM
Matched set.
Never seen a load but they assure me its not overloaded.
Lint screen is clean they don't use dryer sheets.
#58 one of the 1st I check when doing a dryer.
Time again will tell.
#38 Patricio
Patricio
    Opa
  • 1,556 posts
Posted 22 October 2013 - 05:41 AM
Update,  Replaced Heat board & relay along with thermal fuse a month ago.   No callback since.  That took care of this headache.   Another win in a long drawn out battle.  Whew. :wink:
#39 bigbuck
bigbuck
    Sōhei
  • 236 posts
Posted 22 October 2013 - 08:13 AM
You don't give up.Good for you.Great job.
