GE GBS22HCRBWW fried and crispy mutherboard
1 reply to this topic
#1 Skydiver
Skydiver
  • 1 posts
  • Flavorite Brew:Hoegarten
Posted 27 August 2013 - 12:48 AM
Hello I have a GE GBS22HCRBWW fridge that started smelling like a board was frying.
I unplugged and removed mobo cover and found the board badly scorched. The plug at the bottom left was partially melted and will need to be replaced as it is not reusable. I looked at the board that you are offering as a replacement but the number on the board is not the same nor are the connection plug placements for the harness. The number on the fried board is WR55X10416 with the GE part# 200D5837G004.
Is the board you offer a replacement that will work even though the pictures are not the same nor plug/harness. Also do you sell replacement plug needed to replace?
With the electrical fire is there another component that would have failed that caused the meltdown?
I have pics I can provide you if needed.
Skydiver.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 27 August 2013 - 01:23 AM
post pictures (somewhere)
The manufacturer has replaced part number WR55X10416
with this item, part number WR55X10942
http://www.repaircli...R=154&N=1531075
Main-Control-Board-WR55X10942-01091474.j
