MarquisEXB
Fisher Paykel DGGX1 US - Drum Repair - First Screw Stuck?
3 posts in this topic
I'm trying to repair a DGGX1 top loading dryer. I've taken it apart before, following this video and put it back together before vacation.
Went to take a second tackle at it, but as I removed that first screw the part udner it (not sure the name - looks like a flat silver washer about 3 inches in diameter) is moving with it. The whole thing is making a large sqreeching noise as I do it. Now it seems that either tightening or loosening it has no effect. Although I haven't done either for a long period of time.
Not sure what to do. Any suggestions would be greatly appreciated.
Thanks!
OK I just pulled it out of the chasis, and it seems like the drum bolt is loose. Not sure what to do now...
Update: As I start turning the inside bolt, the outside one goes in/out. It seems this inside bolt is turning the whole drum. However I'm unable to use the other bolt to stop it. I can stop it from turning, but can't stop it from going in/out. So if I try to loosen the inside the bolt goes out. If I try to tighten it, the bolt goes back in.
