caloric built in oven model# RWS202
2 replies to this topic
#1 alamo3
alamo3
    Ikkō-ikki
  • 58 posts
  • Flavorite Brew:coke zero
Posted 27 August 2013 - 10:49 PM
This is a built in single gas oven that appears to work but takes nearly 30 minutes to get up to 350 degrees and 50 minutes to get up to 450. turn it on and the ignitor glows for about a minute and then burner bar ignites with a pretty blue flame all the way around but takes FOREVER to heat up. the entire time the flame is on nonstop till it gets to 350 (took 30 minutes )then thermostat kicked off burner and indicator light went off (just like it should) kicked it up to 450 and immediatly it came on and stayed on till it reached 450(but took 21 minutes to go from 350 to 450) . my theory and i could be wrong is simply not enough gas because while the flame is constant it extends out from burner bar about 2 or maybe 2 and a half inches at most. thought of trying to adjust gas valve nipple on top of valve but have done that in the past with gas stuff and got a screwed up flame(either lots of yellow dancing flame or floatinging flame that didnt seem to come in contact with burner bar) looking for ideas or confirmation that not enough flame is the problem and i need to adjust flame.  Oh i should mention the door is closing properly and the door gasket such as it is (one of those thin u-shaped rubber ones) is in placeand sealing as good as this type ever did.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 28 August 2013 - 04:13 AM
it may be a weak glow Ignitor
When the get weak, they may not open the Gas Safety Valve completely.
It should only take about 30 seconds for the Ignitor to fully heat.
If you measure the amperage at that time, it should be about 3.0A
I believe the Broil Ignitor is the same part.
You could try swapping the those.
http://www.repaircli...sp?R=154&N=1191
#3 alamo3
alamo3
    Ikkō-ikki
  • 58 posts
Posted 28 August 2013 - 07:03 PM
yeah i thought about that too but when i have had that in the past it would be where the flat style ignitor which mormally draws 3.2 amps was bouncing between 3.0 and 3.2 and it would eventually lite and rapidly go up to 350 (5 to 10) minutes but when it went to cycle back on it wouldnt come back on (OR the really difficult one to catch) it would cycle 2 or 3 times and then would quit coming on . In these cases the people would always say it preheated fine but wouldnt stay on long enough to cook whatever they were cooking (wouldnt maintain temp in other words). i personally havent seen what you mentioned (borderline amp draw not letting enough gas thru) but i see where that could be a possibility. guess ill check amp draw first for 3.2 before i start the game of adjusting the gas valve and air shutter in hopes of getting the right combination for a bigger clean burning flame. must say though the ignitor does pass the old eye test of a bright glowing almost white/ orange instead of the duller orange/orange you usually see with a weak ignitor. thanks for the input.
