No excuses
LG washer dryer combo
4 posts in this topic
I posted something similar a while back. LG mod WM3431HW combo washer dryer. Clothes come out wetter after dry cycle than they do after spin cycle. I have already cleaned out loads of lint from the lint chute, I replaced the pump, the machine has heat and good flow of air. I would be most grateful for help, the customer is just a little p.o.'d.
Whenever servicing the LG combo WM3431---identify/correct any fault/defect---then remove all lint from the DUCT ASSY.
Replace the DRAIN MOTOR (4681EA2001T) and WATER VALVE (AJU71030102).
In most cases---this should be done about every three years for a family of 3 or more (very heavy usage/cycle run times).
Thank you John63. I will replace the H2o valve and hopefully not hear from p.o.'d customer again.
<<< I will replace the H2o valve and hopefully not hear from p.o.'d customer again.>>>
A customer that is "po'd" is understandable---if they've had a problem with their appliance.
Provide your customer with the following information---and they'll be more informed as to how best to use the combo washer/dryer.
Use ONLY "HE" type detergent in the following dosage (for this small-size tub):
HE (regular concentration): (1) Tablespoon Per Wash
HE 2X (double concentrated): (1) Teaspoon Per Wash
HE 3X (triple concentrated): ***NOT RECOMMENDED***
Remind the customer *not* to load the washer tub past the ***black hash mark*** that is located on a sticker/emblem---on the left side of the door/tub opening.
A fully loaded tub will *wash* fine---as long as the clothing is not compressed/pushed into the tub but---the laundry will not dry very well (taking up to 6 hours to dry laundry).
Advise the customer to select/use the TIME DRY dryer cycle rather than *automatic*.
They will need to select the desired cycle RUN TIME for the dry cycle.
After a month or so of using the TIME DRY cycle---the customer will become familiar with the amount of time needed to adequately dry an average-size or type of laundry load.
Using the TIME DRY cycle in a combo unit---eliminates/avoids using the dual THERMISTORS that are located on the DUCT ASSY.
This also allows for a higher temperature during the dry cycle (laundry dries faster).
Use the *automatic* dryer cycles for Delicates only.
Armed with all of this *very* relevant information---the customer becomes less frustrated/more relieved---that not only do they have far better *intel* on their particular combo---but that you ACTUALLY CARED to inform/educate them about it.
It's best to write this down and give it to the customer.
It's *impossible* for the average customer to *memorize* all of this:)
Good Luck.
