Heidi Boutin
PAV2300AWW works fine on reg cycle, trips cb on delicate
6 posts in this topic
Hi, I have a Maytag Performa washer. I recently read through and replaced the snubber and gave it a new belt since I was under there. :thumbsup:
Everything works fine, except this:
when I put the selector to delicate, pull the knob, it fills up with water, ok.  then when it gets to start to agitate, it blows the circuit breaker in my main electrical panel. :woot:
What gives?
Any suggestions?
Thanks!
~Heidi
It would seem to be a bad Wash Motor
OR bad contacts in the Timer ..
(or wiring)
check to see if the connections to the Washer Motor are good / tight / not corroded
OR, maybe you can do without the Delicate cycle ...
  Did it work properly in delicate cycle before you replaced the snubber ring?
Eric
@Fairbank56,
yes, it did work fine before. I opened up the top last week to check the connection on the top of the motor, felt/looked good.
Sensei....I love my Delicate Cycle! Besides- I just got a load of cashmere sweaters from Goodwill (cheap!).
I was wondering if the contacts on the timer were corroded and just happened to fault then since I worked on it.....
Found a bunch of timers on ebay....
Before ordering a timer I would check the wiring from timer to motor. Maybe a pinched or broken wire somewhere? If wiring is ok it could be the timer but old also could be the motor. Do you have a meter to check ohms?
