daewoo mod dwd-wd3011ww washing machine
26 replies to this topic
#21 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 971 posts
  • Flavorite Brew:orange juice
Posted 21 September 2013 - 04:52 PM
have you ever changed the bearing on one of these front load washers?  It probably is a bearing as it doesn't make noise on the wash or in general when the motor is running.
#22 john63
john63
    Dean of LG Appliantology
  • 2,212 posts
Posted 21 September 2013 - 10:40 PM
Not on a Daewoo washer---sorry I can't be of more help.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#23 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 971 posts
Posted 22 September 2013 - 12:58 AM
how about on an LG?
#24 john63
john63
  • 2,212 posts
Posted 22 September 2013 - 01:57 AM
Yes---but I have no access to Service Manuals nor Part Numbers.
Daewoo may be nearly identical---or totally different (hard to know without any experience).
Even if you undertake this repair---where can parts be ordered/obtained (any website available)?
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#25 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 971 posts
Posted 22 September 2013 - 11:58 PM
thanks for all your help,  I have a better feel for what I'm doing now.  Being in Costa Rica I haven't had much experience with these.  Nothing major.  It looks like this one is going to need the pcb board for sure.  I thinks the bearings are available but the seal would be hard to find by itself.  Any way I have enough info now to proceed.  Thanks a bunch.
#26 electro_doc
electro_doc
    Senpai
  • PipPipPipPip
  • 971 posts
Posted 04 April 2014 - 06:18 PM
Well my customer ordered the control board where the buttons are, the one on top in the front panel.  The washer is doing the same thing.  Long story short I ended up with it, too much to spend for my customer.  I found that the bearing seal has been leaking and the bearings are definitely bad.  The thing that goes on the stater and has a gear in it that fits on the tub shaft is cracked and the whole gear ting turns inside this cover moving the tub just a little compared to how fast it is spinning.  I'm guessing I need this part and bearings and seal at least.  This however may be all thats wrong if I could only find the parts.  It's a DWD-WD33WS   Does anybody have a service Manuel or an idea where to get parts.  Thanks
Doc
#27 Scottthewolf
Scottthewolf
    Senpai
  • 2,944 posts
Posted 05 April 2014 - 11:42 PM
Does anybody remember the Chevrolet Aveo?  It was made by Daewoo.  I couldn't believe you had to remove the grille to replace the headlight bulbs.
Scott Wolf
