GE Mongram ZD0710K10SS dishwasher won't start
7 replies to this topic
#1 woodygg
woodygg
  • 5 posts
Posted 02 September 2013 - 02:36 PM
Our dishwasher just stopped working. All the lights seem to function properly and are acting normally. There was water left in the bottom of it as well.
I found the paper and have tried running the service mode.
When I activate the service mode, I hear a sound that sounds like the door is locking and the lights all light up for a bit then go off. When I push the various buttons to test each service mode item, the light comes on and I hear a click near the top of the door and then nothing (nothing for any of the button - nothing runs).
In addition, I took out the dishwasher and took apart quite a bit of the drain system, tubing, etc on the bottom and nothing was blocked. I checked the drain tube, the little red valve, etc.
I'm have a vom, and am comfortable with electronics, electrical, etc. so need some advice to hone in on the problem.
Thanks so much!
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 02 September 2013 - 03:39 PM
... ZD0710K10SS
check that model number again ..
is there a letter missing ?
ZxD0710K10SS
#3 woodygg
woodygg
  • 5 posts
Posted 02 September 2013 - 04:24 PM
ZxD0710K10SS
oops.. yes.  ZBD0710K10SS  thanks
#4 olyteddy
olyteddy
    Kohai
  • 442 posts
  • Flavorite Brew:Earl Grey
Posted 05 September 2013 - 10:27 PM
Is the door switch stuck?
#5 woodygg
woodygg
  • 5 posts
Posted 07 September 2013 - 11:52 AM
not sure, how would I check?
#6 olyteddy
olyteddy
    Kohai
  • 442 posts
Posted 07 September 2013 - 12:14 PM
There is no lock per se, rather there's a tab with a plastic block on it that sticks out at the top of the body of the DW. That engages a plastic plunger in the hole at the top of the door. That plunger activates 2 microswitches. If the block on the end of the tab isn't pushing it down right or the plunger is sticking those switches don't activate and nothing happens.
#7 woodygg
woodygg
  • 5 posts
Posted 14 September 2013 - 10:03 AM
turns out that was exactly the problem!  the switch wasn't be depressed all the way anymore.  thanks!!!!
#8 olyteddy
olyteddy
    Kohai
  • 442 posts
Posted 14 September 2013 - 02:12 PM
No problem. Out of my 'flock' ('herd'?) of six or seven hundred of that style DW it's happened to me once or thrice...
