zincmann
Amana ARG7303LL Not heating to proper temperature
7 posts in this topic
I have a 14 Year old Amana Gas Stove which we take very good care of our appliances.
I have replaced in the last year the Oven Igniter (the one that heats the over to temperature) because it was not getting past 200 Degrees.
Recently we noticed that it is not heating to temperature it heats up because the gas kicks on and I know the oven igniter is working properly but i did some research and I was told that even though it says its been preheated and the beep goes off its about 150 - 200 degrees off from where it should be.  With that information I replaced the temperature probe and apparently that has not fixed the issue.  I have checked the temperature with a brand new oven thermometer and it is indeed about that temperature delta.
My wife says the broiler is not working at all, we are trying to cook some chicken in the oven (as noted earlier its not hitting the accurate temperature so we are on 450 and its showing 300, since this oven does have a broiler igniter could it be the broiler igniter?
Does the broiler play a part in getting an oven to temperature?
There are three igniters in the stove, the bake igniter, oven igniter and a broil igniter.
Any thoughts? I do not want to keep throwing parts at the problem but hoping to eliminate one or the other because the broiler is not firing im guessing its the broil igniter.
Help would be greatly appreciated
... is not heating to temperature it heats up because the gas kicks on and I know the oven igniter is working properly
... I replaced the temperature probe
... Does the broiler play a part in getting an oven to temperature?
... broiler is not working at all,
... There are three igniters in the stove, the bake igniter, oven igniter and a broil igniter.
1) Ignitor could be weak and not opening the Gas Valve completely.
2) this one ?
http://www.repairclinic.com/referral.asp?R=154&N=1242000
If not a bad Thermistor Sensor, may be a bad Oven Controller
Have you recently used Self-Clean ? :nono:
http://www.repairclinic.com/referral.asp?R=154&N=503000
3) not on this model
4) may be a bad Broil Ignitor
5) only two Ignitors . . .  Bake and Broil
Bake Ignitor
http://www.repairclinic.com/referral.asp?R=154&N=793357
Broil Ignitor
http://www.repairclinic.com/referral.asp?R=154&N=1191
RegUS_PatOff Thanks for your help and detailed answer.  I guess i have a few things to look at first i just do not want to throw parts at it as i did with the Oven Temperature sensor as you identified above
By the way I replaced the oven igniter about a year ago...the original one lasted 12-13 yrs i bought an OEM Part is it possible it would fail again that soon?
hard to say.. if you could measure the Amperage draw of the Ignitor,
it should be at least 3.0A after 30 seconds
I have a multi meter i will do that then.  Where would I put the probe? Near the igniter? Or on the leads that are attached to it?
normally: $14.99
Sale: $9.99
extra 20% off with coupon from various sources
click on picture
unless you have a clamp-on type ammeter,
you'd have to disconnect one lead of the Ignitor and use the 20A function of your meter connected in series.
