Frigidaire dishwasher
9 replies to this topic
#1 lsmith4
lsmith4
  • 12 posts
Posted 03 September 2013 - 10:09 AM
Hi
Ive have a frigidaire dishwasher FPHD2491kfo with flashing ER code no other code after - just ER.  other controls are flashing too (normal wash, add rinse aid (which I did). delay start and air dry) I can press other wash settings, and they just illuminate and go back to normal wash.  I have also taken door apart and checked ribbon cables that look fine -- any ideas
thanks
#2 PDuff
PDuff
  • 2,158 posts
Posted 03 September 2013 - 12:53 PM
Provided the door switches check good and there is no following fault code displayed after "ER" it usually means a stuck key on the touch control.  In most cases the "ER" code is caused by the top membrane switch.  A quick way to test which membrane switch is bad:
With the "ER" fault code displayed, remove the top membrane ribbon from the control and then press the Start/Cancel pad.  In 5-10 seconds the "ER" code should clear and the display should be blank at this time.  Press the Start/Cancel pad once more, this will restart the previously selected cycle.  If the "ER" code does not clear or the unit does not start, replace the front membrane switch.
#3 lsmith4
lsmith4
  • 12 posts
Posted 05 September 2013 - 07:47 AM
Thanks for your reply, could you tell me which one is the top membrane ribbon
#4 PDuff
PDuff
  • 2,158 posts
Posted 05 September 2013 - 07:52 AM
On your model it's the touch control on the top of the door.  The switch membrane is part of the console P/N 5304475578.
    Shōgun
  • Master Samurai Tech
  • 31,387 posts
Posted 05 September 2013 - 08:10 AM
Console:  http://www.repaircli...4475578/1565351
#6 lsmith4
lsmith4
  • 12 posts
Posted 05 September 2013 - 12:02 PM
got the unit apart and was able to disconnect the "black" ribbon cable but not either of the white ones (didnt want to yank) - pressed and held the start - nothin --  did i take off the correct ribbon?
?ui=2&ik=bebeb616fb&view=att&th=140ef10d1a3f326e&attid=0.1&disp=inline&safe=1&zw&saduie=AG9B_P-5Y2SSSlx0CmMyk-ErB7xv&sadet=1378400497235&sads=tIvCuxSgYAZqU5R46_w6pXZNdUE
#7 lsmith4
lsmith4
  • 12 posts
Posted 06 September 2013 - 12:44 PM
Sorry for my confusion!  Im not sure what to do now!! - there's a lot of wires and "ribbons" in there!  I disconnected the green ribbon with the black connector labeled 46/09 and nothing happened with the "ER" code- does this mean I need the front membrane switch?
?ui=2&ik=bebeb616fb&view=att&th=140f45d9900d1bcc&attid=0.1&disp=thd&zw
#8 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 06 September 2013 - 01:11 PM
pictures inside your emails don't appear here
#9 lsmith4
lsmith4
  • 12 posts
Posted 06 September 2013 - 01:14 PM
It was suggested to "remove the top membrane ribbon from the control and then press the Start/Cancel pad" it dont know which one it is!!!
#10 lsmith4
lsmith4
  • 12 posts
Posted 08 September 2013 - 08:23 AM
Sorry about the pictures - I could see them - anyway, -- Is the top membrane the touch keypad controls? also for a
stuck key which part do I need to replace - the keypad or circuit boards
5304475569 or 5304475571
