Sign in to follow this
Followers 0
dryerman45
LG REF/FREEZER
3 posts in this topic
Hi,
I have a LG R/F Model LMX25984SW.The water coming out of dispenser is weak,and the icemaker is making small ice cubes.I removed the line coming out of valve and it is strong,then I checked the water coming out of filter valve and it is strong also.It goes from there thru the top of fridge and then into door,so I was hoping you would know what that might be.Iam hoping it is not inside door
Thank you,
SAMANERA
When was the last time you changed the water filter?
I hope you don't also have a reverse osmosis water filter on your house water line, that messes up refrigerator water filters.
Partially frozen lines can do it. What are the fridge temps ? I had a customer with his fridge at 34f and this happened.
Also check house water pressure. maybe the pressure is initially strong but reduces quickly, especially if water is being used somewhere else at the same time.
I have also experienced this with a bad filter head assembly. Initially strong water flow then reduces due to air in the line.
Is the fridge connected to a faucet or a saddle valve?
The other thing is to make sure the problem with the icemaker and dispenser are actually related and not two separate problems.
Followers 0
