dave01978
Dishwasher wont drain
8 posts in this topic
I have a whirlpool DU912PFGB0 That does not drain, I cant tell if the pump is pumping, The hose was not clogged, no garbage disposal, not sure if there is a check valve in there somewhere?
Any Help, or even service manual would be greatly appriciated,
Dave
There is a check valve P/N 675238 located on the right hand side of the motor where the drain hose attaches.  You can remove the drain hose and unscrew the check valve (counterclockwise) and look for a restriction.  Make sure the rubber flapper is intact and not binding.
1 person likes this
Wisdom!  Let us attend!  http://fixitnow.com/wp/2008/11/14/older-whirlpool-kenmore-dishwasher-wont-drain/
Have you tried 'suck starting' it with a Shop Vac? Sometimes that's all it takes... :thumbsup:
Thanks, that was it was a little bit of junk in the valve, didnt realize that came off when I first looked at it.  Also at first when taking the hose off you could see that draining, but i guess when the pump runs it was forcing it down and causing more of a blockage.
thanks a bunch for your help
Dave
Thanks for the update, Dave.  That's a great dishwasher.  It will love you long time.
Treat you real good, GI.
