Sign in to follow this
Followers 0
elmonducky
Maytag MFI2067AES
8 posts in this topic
No ice production I/M and water valve have been replace.  Good air flow into "ice box"  -5 in freezer.  Previously found freezer set by customer to +5, turned down to -2 for freezer 38 for fridge.  Still no ice but fridge is now down to 28 and of course everything is freezing.  Main board seems to be only common denominator.  Any thoughts?
... MFI2067AES
MFI2067AESxx
any digits at the end of the model number ?
No extra digits.
No extra digits.
http://appliantology.org/files/file/1204-maytag-fridge-mfi2067aes/
Maytag Fridge
MFI2067AES
Repair Part List - MFI2067AES w/wiring diagram
may be similar
but not the same as:
MFI2067AES0
MFI2067AES1
MFI2067AES2
MFI2067AES4
MFI2067AES5
MFI2067AES6
MFI2067AES7
MFI2067AES8
MFI2067AES9
MFI2067AES10
MFI2067AES11
MFI2067AES12
MFI2067AES13
Check the icemaker fill tube for ice restriction.  I've found the rubber elbow at the top/outside cabinet will crack, allowing air in to cause water seepage.  Might even find standing water in the fill tube elbow recess.
Thanks. Why should we have freezing temp in fridge when freezer temp lowered?
Could be cold air leaking into the f/f section from the ice room.  I remember seeing a bulletin about gaskets for the ice bin cover but I can't remember if it was for Maytag or LG.  I'll keep looking.
Followers 0
