JerryCalhoun
Front load Frigidaire will not agitate or spin (sometimes)
5 posts in this topic
I have a 2000 Stackable Frigidaire Gallery washer/dryer set in very good condition. The washer stopped agitating/spinning.  I went through the trouble shooting procedure found on the wiring diagram to rule out the motor. I replace the door switch. If I unplug it, remove & re-connect the wires to the motor as well as remove & re-connect, it will then go through one cyle of wash normally (agitaing & spining). And then it will not.  If i unplug undo the conncections & re-connect, it will work, for one cycle.  Is it probably the main circuit board?
model number ?
fwt449gfs2
Well, it turned out to be the motor...by spininnig the drum it would allow the contacts to be in a different position & it would work...sometmes.  I saw the motor arcing as it was under load.
Just for anyone trying to figure this one out.
