Frigidaire Affinity, will not spin fast
6 replies to this topic
#1 Hdelll
Hdelll
  • 4 posts
Posted 07 September 2013 - 06:05 PM
Hello, I am hoping someone can point me in the right direction. I have a Frigidaire affinity washer. It started acting up and not draining, and after looking over this forum I took apart the drain assembly that hooks into the pump. There was a lot of gook clogging up the plastic filter in there, I cleaned It up and checked the pump to make sure it was clear also. everything looks clean and open. Water seems to drain fine.
However the washer will not spin past a slow speed in the final cycle, or sometimes it does at the very end for 15-20 seconds leaving clothes still very wet. I keep getting an error code 21, saying slow drain. So yeah no clue where to go from here. Any help is appreciated, with 2 kids and a disabled person in the house we have a ton of laundry needing cleaning.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 07 September 2013 - 07:37 PM
model number ?
It won't Hi-speed Spin untill all the water is Pumped out.
Sounds like a Drain problem or the Pump is getting weak
#3 Hdelll
Hdelll
  • 4 posts
Posted 08 September 2013 - 06:41 AM
Model is  ATF8000FS2, and thank you for responding.
    Shōgun
  • Master Samurai Tech
  • 30,176 posts
Posted 08 September 2013 - 07:02 AM
The pump is failing under load.  The rule with front loaders is:  No pumpy, no spiny.
Here's your pump:  http://www.repaircli...mber=ATF8000FS2
#5 Hdelll
Hdelll
  • 4 posts
Posted 08 September 2013 - 11:47 AM
Thanks a lot guys. Will have to order one up.
#6 Hdelll
Hdelll
  • 4 posts
Posted 09 September 2013 - 03:09 PM
Weird thing now, seems to work just fine as long as I do not use maximum spin. on fast or lower it works just as it should. This still sound like a bad pump?
#7 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 900 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 09 September 2013 - 05:32 PM
http://m.youtube.com...h?v=OThhUNI0oL8
Check your bearings. We do this before doing any work on all front load machines.
Edited by micabay, 09 September 2013 - 05:33 PM.
