mshulan
asko 12004 washing machine pump leaking
2 posts in this topic
I have an older asko 12004 washer that works fine but is leaking slightly at the pump. I inpsected it in operation and then took the pump out and it is leaking at the impeller seal.  It seems that the correct pump is not available (part # 8055565).   Is there another pump that would work? If not, could I simply replace the seal? (I am not sure how the impeller comes off the shaft, or how I would obtain the right seal...)  thanks.
No, the drain pump for this machine is no longer available. Time to retire the machine.
