Oven pilot light on, oven burner does not turn on.
3 replies to this topic
#1 dragon
dragon
  • 16 posts
Posted 09 September 2013 - 08:51 AM
Grasshopper question about Gas oven with always on pilot light not working.
Sunray SBP26AA0 and Caloric RBP26AA0.  Identical free standing gas stoves with 2 always on burner pilot lights, one always on oven pilot light.  This identical model sold under at least 2 names.
Have two units, one oven that works and one oven that does not work.
Both installed maybe 1990's in apartment.  Unused for 10 yrs and gas off.
Sunray SBP26AA0 with oven problem.
Gas company turned on gas, lit pilots, oven worked, I saw oven burner turn on.  Gas co guy cleaned pilot, "some white stuff on it", he said.  Checked for leak with soap water spray.
1 week later pilot on, oven burner not turning on when turning oven knob.
Pilot does enlarge and appears go down to cover the bulb of thermocouple when oven know turned to On.   No click after 30+ seconds.  No apparent change after 20 min waiting.
I waited 20 min and no turn oven burner turn on.  No change.  No clicks.  I smell no obvious gas.
Caloric RBP26AA0 with working oven.
Checked my working oven.  Pilot appears to behave same way as non working oven.  Oven knob on, pilot enlarges downward over thermocouple bulb.  The difference is after 20-40 seconds I hear a click which I think is gas turning on, see and hear the oven burner flame, flame goes over spreader, and oven works normally.
Do I have problem with thermocouple-gas safety valve assembly?  This is a Hyper Wyman 4157094.
Not available at usual parts stores.  Available on flea-bay.
If this is the issue, does come off by just unscrewing 2 gas lines and 2 visible screws in the pictures below?
Do I have an oven thermostat problem?  Or something else?
Here are pictures of thermocouple safety valve and pilot light.
http://s693.photobuc...P26AA0.jpg.html
Grasshopper thanks you.
#2 PDuff
PDuff
  • 2,059 posts
Posted 09 September 2013 - 12:18 PM
Most likely a problem with the thermocouple and safety valve.  Will probably have 4 mounting screws and you may have to adjust the orifice hood for a properly flame.
#3 dragon
dragon
  • 16 posts
Posted 25 October 2013 - 04:21 PM
Replaced pilot and gas safety valve with used parts from ebay.  Checked fixitnow but parts not available.  Old pilot flame seemed big enough but had to remove oven burner to remove pilot.  Works normally.
Removed bracket from old safety valve transferred to replacement.
This Harper Wyman 5817 safety valve was common and comes in many slightly different models.  Many differ only in removable  bracket.  Hood needs to be set according to instructions and old one can be reused if needed.
Pilot also old and not available on fixitnow.  Cross reference shows many numbers for same part.
5817 valve partly installed   http://i693.photobuc...17installed.jpg
Oven burner works  http://i693.photobuc...VENBURNERON.jpg
Instructions for 5817
http://i693.photobuc...instrsheet1.jpg
http://i693.photobuc...nstrsheet-2.jpg
Cross reference pages for 5817 valve
http://i693.photobuc...VESB_Page_1.jpg
http://i693.photobuc...VESB_Page_2.jpg
Cross reference page for pilot
http://i693.photobuc.../OVENPILOTS.jpg
#4 dragon
dragon
  • 16 posts
Posted 25 October 2013 - 04:27 PM
Thanks, PDuff.  Correct diagnosis.
Here is bracket that transferred to replacement valve.  http://i693.photobuc...5817BRACKET.jpg
Old pilot flame seems big enough.  http://i693.photobuc...tY07697200b.jpg
