  • Announcements
jambatt
Kenmore 417.44102301
6 posts in this topic
Will not go into high speed spin. Dial on timer does not advance.  Just does the clockwise and counter clockwise tumble with drain pump running. Does this unit get it's signal to advance to the next cycle from the spin control board like the models with the touchpad interface or does the timer advance to the next cycle via motor and cam arrangement??
... Will not go into high speed spin.
... Dial on timer does not advance.
... Just does the clockwise and counter clockwise tumble with drain pump running.
... Does this unit get it's signal to advance to the next cycle from the spin control board
1) not until water is Drained out
2) Timer Motor is also controlled by Motor Controller
3) see # 1
4) see # 2
http://appliantology.org/files/file/1214-kenmore-41744102301/
Kenmore Washer F/L
417.44102301
5995442620 parts
134576400 tech
Thanx.
Sounds like a classic case of a bad door lock assembly.
I can tell Brother jambatt is an old timer.  Anybody that calls the motor control a "spin control board" or "speed control board" has been around since White-Westinghouse.
