ballacm
Whirlpool Duet Washer Starts, spins once, doesn't fill & drain pump turns on
3 posts in this topic
My 3 year old whirlpool duet washer will power up, I can select a cycle, and start the machine.  The door locks when started and then the tub spins about 1 revolution and then the drain pump turns on.  No water enters the tub.
Before this started there was an error message F017 (I think) and the drain pump was running constantly at a very slow flow.  I found that the filter going into the pump was clogged with a sock.  Cleand out the filter plugged back in and everything seemed to be normal.  Then the issue above happened.  I think I've narrowed this down to the water level sensor?  Has anyone seen this before?
model number ?
WFW9450WW00
