Samsung dv210 dryer
4 replies to this topic
#1 Inferno493
Inferno493
  • 3 posts
  • Flavorite Brew:Ninkasi oatmeal stout
Posted 10 September 2013 - 12:42 AM
So I experienced a moment of infirmity when swapping out the power cord on my dryer and hooked the ground to the wrong terminal block. I hit the power button, the display lit up and it smelled pleasantly of ozone for a brief moment at which point the display went dark. I fixed the power cord but there is no improvement to the display. I pulled the circuit board and the display board to inspect them. There is no visible indication of damage. Is there any way to test which one needs to be replaced?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 10 September 2013 - 06:11 AM
... when swapping out the power cord on my dryer and hooked the ground to the wrong terminal block.
... circuit board and the display board to inspect them....no visible indication of damage.
May be able to "smell" each board
May depend on which wire(s) were mis-wired ?
3 wire OR 4 wire cord ?
L1
N
L2
ground
Is it properly wired, now ?
Probably at least the main Circuit Board
#3 Inferno493
Inferno493
  • 3 posts
Posted 10 September 2013 - 11:15 AM
The neutral wire and L1 were swapped. They are connected correctly now. Nothing looks or smells wrong with the boards. I'm guessing that I fried the EPROM on the control panel board as it looks like the only microcircuit.
    Shōgun
  • Master Samurai Tech
  • 31,152 posts
Posted 10 September 2013 - 11:25 AM
Post the complete model number.
Your unit has at least two circuit boards:
Main PCB:  http://www.repaircli...200123C/2073647
Main-Control-Board-DC92-00123C-01508940.
Interface PCB:  http://www.repaircli...200303B/2073750
#5 Inferno493
Inferno493
  • 3 posts
Posted 10 September 2013 - 11:28 AM
Dv210aew/xaa. I pulled both boards in regard to the above posts.
