srburk
Leaking Whirlpool dishwasher DU920PWKQ0
13 posts in this topic
Started leaking water between the bottom of the tub and the panel near the beginning of the rinse cycle...about a gallon's worth before I noticed and stopped it from running to clean up.
I see that I need to take the panel off and pull out the machine to run it to see where the leak is coming from, but I am curious about one thing.  I could also hear sloshing inside the door and water was leaking out of the door just under the control panel on the left side.
I'd have included a pic but am waiting for help to arrive to help me pull it out.
No suds.  Watched it run through and it begins to leak at the rinse cycle.  Pumps out water o.k.  Top leak stopped after we took the inside of the door off--I think we inadvertantly cleaned the vent.
Not leaking under the tub next to the floor.....next step to pull it out of the cabinet and watch it run?
Hubby says water is coming directly from screw holes at the bottom of the door....somehow the door itself is filling with water and then the water is leaking out the bottom.  He thinks the water is spraying through the vent into the door's interior?  Would that indicate a broken arm?
Remove the bottom access panels and watch underneath the dishwasher with a flashlight while it's running to see exactly where the leak originates from.
Also check the square rubber grommet at the dispenser cup latch.  It's a common source of a door liner leak on the DU900 series.
The vent actually was clean when we(the royal we--I post, he takes apart) took the door cover off. No leaks under the dishwasher while running.  Will check the other stuff tonight, thank you!
I think it's fixed.  Thank you.  I must admit a bit of homeowner stupidity, though.  We took all parts off in the inside and looked; nothing was wrong.  So we went back to the drawing board and started from step one.  We popped off the vent cover....now we had taken the inside of the door off and had seen the vent from the backside, and I had looked at it with a flashlight from the front side.  It looked clean.  So when we went back to step one and just popped the cover off........it was completely stopped up with mineral deposits (our water is very hard).  Took a screwdriver and a vacuum cleaner to clean it out and it is nearly through the rinse cycle with nary a drop of water where it shouldn't be.
I thank all of you for the help; and the Samurai for the most excellent website.  We have fixed, ourselves, so far: dishwasher, refrigerator (twice), dryer (once), washer (twice), and the oven.  That saved me at least $450 in service calls.  That is a big part of our budget, and I appreciate it so much that all of you are willing to offer advice. Best $5 I ever spent.
