Sign in to follow this
Followers 0
elmonducky
Frigidaire Double W/O GLEB27T8CSA
7 posts in this topic
Upper oven broiler works but no bake, lower oven no bake or broil. Diagram missing.
Yes
THis is the 2nd time ive run into this problem within the last 3 months.  Same model, same problem.  Turns out the upper and lower relay boards burned out.  Both times the upper goes then within a week the lower stops working.
No service flashes addressing this problem.  Cooling fan motor working?  Tripped thermal cutout or fault codes displayed?
Found both relay boards bad.  Second time in 2 months ive run into this problem on the exact same model.  Ovens fail within a week of each other.
Followers 0
