May Tag Front Load Washer will no spin
3 replies to this topic
#1 errnmlm
errnmlm
  • 2 posts
Posted 13 September 2013 - 03:34 PM
I just replaced the drain pump motor due to leaking. i can hear water draining but it will not spin. Then I notice there is still quite a bit of water left in the drum. the drum spins when it is washing. Help
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 13 September 2013 - 03:53 PM
does this Washer have a model number ?
#3 errnmlm
errnmlm
  • 2 posts
Posted 13 September 2013 - 04:12 PM
MAH6700AWW
    Shōgun
  • Master Samurai Tech
  • 30,526 posts
Posted 14 September 2013 - 07:02 PM
Do you mean you still see water in the inner basket?
Are you saying the basket is spinning when, instead, it should be tumbling back and forth?
