Sign in to follow this
Followers 0
Tone Blair
KENMORE RANGE 790.75903993 LOSS VOLTAGE BROIL IGNITOR
13 posts in this topic
790.75903993
Thought I had a bad broil ignitor
Hooked up a new broil ignitor, it took a long time to start glowing.
I unplugged the ignitor and and checked for voltage, I was getting 120v.
Reconnected ignitor, checked voltage at rear of ignitor plug and was getting 66v.
Is this a computer problem?
Is it losing voltage somehow when a load is hooked up??
I've never seen this before.
Thanks!!
Broiler does not work.
about the same voltage ?
Not sure what ya mean Reg, but I was only getting 66v with the broiler ignitor connected
I'm sorry, I meant
Does the BAKE function work OK ?
Oh yea, bake works fine, strictly broil, I'm guessing the computer is losing voltage somewhere when a load is hooked up, the relay??
So how would that happen?  Is the contact just bad and not sending enough voltage??
check back in a few minutes ...
... Is the contact just bad and not sending enough voltage??
yes, would seem to be ..
Relay K2
also check the Gas Safety Valve
should be no more than 3v across each coil
OR about 1 OHM across each coil
Ok, cool, i checked safety for ohmd, was getting about 1, i told the customer it was the computer, i dont think hes gonna fix it.
Might just be bad solder connections on the relay legs on the board.   I find this alot it seems on Frigidaire range boards.
Thanks budget, i know some people might solder back together, but i dont like messing with them, and the customer doesnt want to shell $300 for the computer.
KENMORE 790.xxxxxxxx made by Frigidaire
c.2000
good website for prices/sizes/features
http://www.ajmadison.com/
Followers 0
