fgeric
Kenmore Dishwasher Mo. 665 Woes
7 posts in this topic
Hello all,
New to the group! So a couple weeks ago my dishwasher stopped working. I did some basic troubleshooting and discovered that the control module was bad. I replaced that and put it back together and everything seemed to be working, except the front panel didn't go together very well. About a week later it stopped working again. I took it apart and metered everying and discovered that the thermal fuse was bad and the connections on the door handle switch were loose, so I replaced that while i was at it (everything went together nice and tight this time). I put it all together and plugged it in. Now the lights come on. The cancel/drain button is working correctly, but the dishwasher doesn't seem to be filling with water and functioning. Any suggestions (besides call a appliance repairman)? When I switch it on I can hear it click on but no water fills, etc.
Thanks!!!
full model number ?
665.xxxxxxxx
Sorry it's a 6651392k600
My eyesight isn't as good as it once was blink.png (see RegUS_PatOff http://www.youtube.com/watch?v=oPAY2LsKVEw )
but there seems to be a digit missing
66513x92k600
. . . . . . 4
. . . . . . 5
. . . . . . 6
. . . . . . 7
I beg your pardon! My eyes are the ones that are questionable. The number should be 66513 592 K600
Make sure the (5) pin Connector (P2) is connected on the Controller
Also, when replacing the Thermal Fuse, you must use the wires that are included in the "kit",
else the Fuse will blow again
1 person likes this
Good call sir! Pulled it and reattached it and BINGO!! Many thanks!!!!
1 person likes this
