kitchen Aid slide in gas oven model YKGSC308LS0
6 replies to this topic
#1 Gnominator77
Gnominator77
    Yamabushi
  • 72 posts
  • Flavorite Brew:Molson Canadian
Posted 14 September 2013 - 04:22 PM
Hi, I have to look at this gas oven on Monday Kitchen Aid YKGSC308LS0 complaint is won't do any oven functions at all. Customer says the display works normally. Everything is keyed in the display but when after hitting start there is no click from the relay board and the display shows the function (bake or broil) should be heating. While looking up the parts to see the breakdown it shows the electronic control board and the power board both in the control panel area. But while looking up the power board part number on Marcone's site part# 9782435 they show that the lookup may be wrong and the power board is located at the lower oven area right hand side. Can someone with experience on these slide in ovens please verify where the power board is. Thank you.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 14 September 2013 - 05:54 PM
http://appliantology...ge-ykgsc308ls0/
KitchenAid Range
YKGSC308LS0
Repair Part List - 8187767
Tech Sheet - 9754241
the Power Control Board is in the Control Panel and connected to the Display Control Board
http://www.repaircli...?R=154&N=940111
#3 Gnominator77
Gnominator77
    Yamabushi
  • 72 posts
Posted 14 September 2013 - 06:08 PM
Great! Thank you very much.
#4 Gnominator77
Gnominator77
    Yamabushi
  • 72 posts
Posted 16 September 2013 - 06:32 PM
It turns out the power board on this model is indeed located on the bottom right side. Easy enough to check before tearing apart the control panel. :)
#5 RegUS_PatOff
  • 33,588 posts
Posted 16 September 2013 - 06:37 PM
http://click.linksyn...kgsc308ls0.html
#6 Gnominator77
Gnominator77
    Yamabushi
  • 72 posts
Posted 16 September 2013 - 06:40 PM
I saw that as well, Reg. Not sure why, but it wasn't where the breakdown said it would be. Maybe it's a Canadian thing.... ha!
#7 RegUS_PatOff
  • 33,588 posts
Posted 16 September 2013 - 06:50 PM
the preceding  "Y" in the model number is the Canadian thing :wink:
